Issues with stylesheets in 3.17 P6
jcbaar
Post by jcbaar »
We have applied Patch 6 of WinCC OA 3.17 and it has totally messed up the styling of the UI with stylesheets. For example we have a style for a button. This style has no font related styles in it. We set the font to use on the button in GEDI. However when we run the UI with the stylesheet it is not using the font we have selected in GEDI for the button but a totally different font. This used to work properly pre-patch 6 and in earlier versions of WinCC OA.
We have a similar issue when styling a table that contains HTML in the column and that HTML changes font style (for example displays some text in bold). Sometimes the text styles are displayed correctly with the correct font and sometimes it is displayed in the wrong font and all HTML defined text styles are removed.
When we run without the stylesheet fonts and HTML in tables is rendered correctly but that totally defeats the purpose of have stylesheets...
There is one "fix" in this patch which seems to be related (80033) to fonts and stylesheets in Patch 6. Can anybody tell me what this fix does and if it can be the source of my issues?
Jan
Andorhal
Re: Issues with stylesheets in 3.17 P6
Post by Andorhal »
Hello.
Sounds related as the mentioned point implemented the correct resizing of fonts in Widgets when the panel got resized.
Please open a service request and send us your stylesheet and panel.
best regards
