Hello!
Tell me please, where can I find much more examples (than are showed in help) for using Control++?
Much more examples for using Control++
- gschijndel
Re: Much more examples for using Control++
Are you looking for specific examples?
Everybody is free to post examples on this forum. Perhaps it helps if somebody sets the good example and starts with a Control++ example.
- MassEffect
For example, there is such function definition in WinCC OA library:
What does this entry "static public shared_ptr<LoginFrameworkController>" mean?
Is this function pointer or template using?
static public shared_ptr<LoginFrameworkController> getInstance()
if(instance == nullptr)
instance = new LoginFrameworkController();
return instance;
Reason: Set code tag
- weirdal
The static function getInstance() returns a thread safe pointer to an instance of the Control++ class LoginFrameworkController.
Implicitly somewhere before, a static variable of the type "shared_ptr<LoginFrameworkController>" by the name "instance" has to be declared. Also, the function getInstance() has to be declared inside of a Control++ class.
So, it's a Control++ function that returns a pointer.
- kilianvp
ctrl++ is similar to c++
