Edit data point value
MassEffect
Post by MassEffect »
I have a question for expert at WinCC OA.
Can I edit data point value that were added to archive using SQL request for example?
Is there any way for that?
adaneau
Re: Edit data point value
Post by adaneau »
First of all, for data integrity you should never change an archived value. However it is possible that due to some errors, you want to manually correct it.
Here is the point, correct it. For this you can have a look into WinCC OA correction values, allowing you to add a correction value to an existing record. Then this value can be used instead of the initially recorded one (which will not be replaced nor deleted!).
If you are using NGA. I guess you can also eventually directly update into InfluxDB a field value (not tag!) but I wouldnt recommend it.
Alexandre
MassEffect
Thank you for your answer! Please tell me, where can I find an extra information about "correction values"?
