Hy guys,
I'm trying to send a test mail via the Communication Center and everything I get when I'm triggering an alert is this error:
WCCOActrl (3), 2013.04.16 14:39:55.907, SYS, WARNING, 196, Illegal byte (0xA7) in UTF-8-encoded string, Codepoint::fromUtf8
WCCOActrl (3), 2013.04.16 14:39:55.907, CTRL, WARNING, 5/ctrl, Location of the following log entry: ccController.ctl Library: D:\\Siemens\\Automation\\WinCC_OA\\3.11\\CommCenter_3.11\\scripts\\libs\\ccMsgQueue.ctc
Line: 699
I haven't used any special signs in the addresses or somewhere else in the Communication Center configuration :/
Greetings
Michel
Communication Center Mail Illegal Byte
- mpoint
Re: Communication Center Mail Illegal Byte
Apparently 0xA7 is § (paragraph or section sign) in ANSI / ISO 8859 encodings. And coincidentally, ccMsgQueue.ctl in Line 699 says:
So I would say that it is a bug in that script. You should contact Support for this. As a workaround, maybe encoding the script as UTF-8 would work.
asTmp1 = strsplit(sComment, "§");
