Hi.
I try to run S7+ driver and establish connection with PLC with symbolic address. I am using Winccoa 3.17.
In Console there is not an obtion for S7+ driver so I can not start the connection.
Is it problem that I don't have a license for S7+ ?
Thank you for help.
Juraj
S7plus Driver
- adaneau
Re: S7plus Driver
What do you mean by no option? There is no manager called WCCOAs7plus in the list of managers which can be added? If no, this probably means that you didnt checked the box for s7plus during installation
You can go to your control panel/ uninstall program and find WinCC OA, then click on modify and check the correct box to install required packages.
Alexandre
Alexandre
- JurajStredansky
Re: S7plus Driver
Thank you Adaneau. You are right, I didn't checked the box for s7plus during installation.
Juraj
Juraj
