at a running wincc project we want to switch to os auth user administration. For a test, I exported everything from the original project with the ASCII manager, set up a fresh test project and read in the dpl file. If I switch from standard to OS auth, then the message with 'This configuration changes the security settings ...' comes up, which I confirm, but nothing happens. There is no error message, not even after 1 hour. If I close the user administration and call it up again, it is reset to standard. The old users and groups have not changed.
I also played through the activation of the OS auth with a fresh project without an ASCII import and everything works fine.
Does anyone have an idea why this might be? Is the original database compromised? (It is also not possible to delete data points via the para-view. It is only possible with the dpDelete() command. But that's another topic...)
Thank you for your help!
Can't switch to OS auth user administration
- adaneau
Re: Can't switch to OS auth user administration
You may have exported more than necessary
. Check if you havent took some system config points which are putting the system in unexpected state (like some IP, port or whatever normally not relevant for new system). Check also your config file and certificates.
Alexandre
Alexandre
