User root at SSA-Project
Discussion about security topics in WinCC OA!
n.kuehl
Post by n.kuehl »
at a running WinCC project we want to switch to the OS auth user administration. For security reasons, the server-side auth (at first for UI only) should be used. Then, according to online help, it is no longer possible to use the user root: But how do you log into the gedi? What's the workflow without a user root?
Thanks for taking my stupid questions ;-)
adaneau
Re: User root at SSA-Project
Post by adaneau »
If you havent changed anything in default users, "para" without password should make it. It basically have the same permissions as root in a default WinCC OA project. Then you should just create your own root user to be used.
Alexandre
n.kuehl
Post by n.kuehl »
but how do you log in with another username? I start an User Interface with paramenter "-m gedi" and the root password is asked. I cannot find a parameter like "-user para".
adaneau
Post by adaneau »
You actually found the good option :)
-user username:password. if no password -user username .
So for you for example, -user para (in the ui option from console). You can also use the config entry username.
Alexandre
n.kuehl
Post by n.kuehl »
Thanks a lot! Should have tried it, but it's not explained in the online help... (probably because of the bad search :D)
dbindernagel
Post by dbindernagel »
This option can be found here in the help:
Reference tables > Manager options > General options
But I agree that it sometimes can be hard to find something in the help.
Searching for "user" does not find this page but "username" gives a hit...
