For some reason I'm unable to install any version of WinCC OA 3.17 (I have tried p2, p3, p5). The installation stops to following error. Any ideas how to get around this? Installation of v3.15 works fine without any problems.
[15:12:20:053]: Executing op: ActionStart(Name=RegisterWCCOAopcsrv,,)
[15:12:20:054]: Executing op: CustomActionSchedule(Action=RegisterWCCOAopcsrv,ActionType=3090,Source=C:\Siemens\Automation\WinCC_OA\3.17\bin\WCCOAopcsrv.exe,Target=/RegServer,)
[15:12:23:119]: Note: 1: 1722 2: RegisterWCCOAopcsrv 3: C:\Siemens\Automation\WinCC_OA\3.17\bin\WCCOAopcsrv.exe 4: /RegServer
CustomAction RegisterWCCOAopcsrv returned actual error code -1073741515 (note this may not be 100% accurate if translation happened inside sandbox)
[15:12:23:128]: Product: WinCC OA 3.17 -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action RegisterWCCOAopcsrv, location: C:\Siemens\Automation\WinCC_OA\3.17\bin\WCCOAopcsrv.exe, command: /RegServer
