While trying to install OA on OpenSuse Leap i ran into a few missing packages. To make it easier for those who plan similar things here are the packages you need to install before installing OA.
Just run following commands and then install OA like written in readme.
in console type
wget https://ftp.lysator.liu.se/pub/opensuse/distribution/leap/15.1/repo/oss/noarch/libicu60_2-ledata-60.2-lp151.2.4.noarch.rpm
then
sudo zypper install libicu60_2-ledata-60.2-lp151.2.4.noarch.rpm
then
wget https://ftp.lysator.liu.se/pub/opensuse/distribution/leap/15.1/repo/oss/x86_64/libicu60_2-60.2-lp151.2.4.x86_64.rpm
then
sudo zypper install libicu60_2-60.2-lp151.2.4.x86_64.rpm
after that check if everything worked right with
zypper info libicu60_2
you should get something like this
Informationen zu Paket libicu60_2:
Repository : @System
Version : 60.2-lp151.2.4
Arch : x86_64
Anbieter : openSUSE
Installierte Größe : 4,8 MiB
Installiert : Ja
Status : aktuell
Quellpaket : icu-60.2-lp151.2.4.src
Zusammenfassung : International Components for Unicode
Beschreibung :
ICU is a set of C and C++ libraries that provide extensive Unicode
and locale support.
This package contains the runtime libraries for ICU.
once that has happend you can now remove the two rpm files since you will not need them anymore.
this is done with
rm libicu60_2-60.2-lp151.2.4.x86_64.rpm libicu60_2-ledata-60.2-lp151.2.4.noarch.rpm
once that is done just install WinCCOA like written in the readme.
