Set panel size from PANEL_REF
andrea.bertorelli
Post by andrea.bertorelli »
Hi everyone!
I can't set the size of a panel from a PANEL_REF contained in this.
On page initialization I am normally allowed to set the page size as:
this.size(100,200);
or
setValue(this.name(),"size",100,200);
But the same thing from another object is not possible, I also tried creating functions in the panel scopelib, but also with invockemethod I was not able.
Some code examples used to try to change the panel size from a panel ref:
setValue($DP_ModuleName+"."+$DP_PanelName+":paginaListTitle","size", 450, yPosition + 50);
setValue("paginaListTitle","size",450, yPosition + 50);
self.setSize(450, yPosition + 50);
//Scopelib in main panel
public setSize(int x,int y)
  this.size(x,y);
//Code on button click in panel ref inside panel
invokeMethod("paginaListTitle","setSize", 450, yPosition + 50);
Its essential that the click on the button trigger the function that changes the panel size, and i don't want use DPEs with some dpConnect on the panel ...
Anyone have any ideas?
dbindernagel
Re: Set panel size from PANEL_REF
Post by dbindernagel »
Have a look at the control function "setPanelSize".
From the help:
main()
   string module = myModuleName();
   string panel = "Testsize";
   bool   fitToBounding = FALSE;
   int    width = 100, height = 100;
   setPanelSize(module, panel, fitToBounding, width, height);
andrea.bertorelli
It works perfectly, thanks for this function, i dunno why I never got to use it!
See you soon! :D
RJM1987
Post by RJM1987 »
Many thanks dbinderangel, I was having the exact same problem and this has solved it! :D
It does beg the question though, why the size attribute isn't available for a panel but others (like position) are. These kind of inconsistencies make developing in OA very frustrating :?
