WinCC OA help freeze - Qt assistant not responding
kuzma
Post by kuzma »
Wincc oa documentation gets always stuck after some time (Qt assistant not responding). The same happens to gedi, when help on the method is opened in the control script editor.
sw: WinCC OA 3.17 p5, windows 10 pro.
Re: WinCC OA help freeze - Qt assistant not responding
How do you detect that its gets stuck?
Do you get a warning dialog?
What does "after some time" mean in detail, e.g. 5 minutes, 30 minutes, 2 hours, ...?
Is a specific action started before it occurs, e.g. doing a text search?
kuzma
Post by kuzma »
Hi Leopold,
The help panel gets grayed out and (Not Responding) text appears in the panel header. No warning dialog appears. I cannot identify any action related to that, sometimes I just return to the help screen after short time (5 min.) and it is already stuck.
I noticed this problem already using older patches of 3.17.
