• Page 1 of 1
joost.lijster@siemens.com
Alertrow removes values when Priority is not column 2
Postby joost.lijster@siemens.com »
When configuring the alert row, I wanted the priority column to be column #7. In the alertrow configuration panel, I removed the columns that were not applicable for me, added a few extra and moved the Priority column to # 7.
When starting the alert row in a panel, it turns out that all values in column 2 had changed to "0".
A little research shows that the function aes_formatPriorityToInt() in the aes.ctl library is hard coded to update the alert priority to an integer, at column 2 (see code below).
In my opinion, this should be made more intelligent. Currently, this makes it impossible to shift the priority to any other column.
aes_formatPriorityToInt(dyn_dyn_anytype &xtab)
int ixtab;
// read the result array
for(ixtab=1;ixtab<=dynlen(xtab[2]);ixtab++)
dyn_anytype atValueOld, atValueNew;
int iLen;
// read the current value
atValueOld = xtab[2][ixtab];
// COMMENT: This column should be determined intelligently!
