Version compatibility inquiry
SMT_SOL
Post by SMT_SOL »
I am currently using WINCCOA version 3.12.
I understand that it is possible to connect to 3.16 DP from 3.12 client.
I'm curious about the compatibility in the UI part.
Based on panel
Can I run a project that is going back to 3.16 in 3.12?
Conversely, can I run version 3.12 as version 3.16?
Re: Version compatibility inquiry
In a WinCC OA system the server and the UI clients must have the same version.
Using different versions in one system is not supported.
A panel which was created/modified with 3.16 cannot be used in 3.12.
An upward compatibility of panels is given but not downwards.
