I have a panel ref which has another panel ref embedded inside it. The embedded panel ref has an Initialise script which I'd like to modify on an instance of the parent panel ref, is this doable somehow? As soon as I select the "Select Object inside PanelRef" tool and click on the parent panel ref, it "decomposes" the entire panel ref and everything inside it, which means I cannot access Initialise scripts at all.
Tom
overparametising a panel ref inside another panel ref
- tpjctrl
- gschijndel
Re: overparametising a panel ref inside another panel ref
It is possible to disable the initialize script defined inside panel refs with the property 'Start Init-Script in Ref' and define a new initialize script at the panel ref itself.
Otherwise you could define a property, which changes the initialize behaviour.
