WinCC OA Project Autostart
13 posts • Page 1 of 2
Alfredo@76
Post by Alfredo@76 »
Hi To everyone,
I would like to know if it's possible to set an autstart for the WinCC OA project, at the server restart.
Regards.
Alfredo.
Re: WinCC OA Project Autostart
Yes search for "WinCC OA as Service" inside the WinCC OA Online Help.
Alfredo@76
Hi Kilianvp
Ok, i'll do it.
Thanks for your support.
Alfredo.
Alfredo@76
I tried to search for "WinCC OA as Service" but no one argument appears.
Could you give some details more?
Thanks.
Alfredo.
Whats your WinCC OA Version? Do you use the english version of the WinCC OA Online Help?
For the german version its "WinCC OA als Service"
Alfredo@76
Version 3.15, English version
dbindernagel
Post by dbindernagel »
Installation > Windows > WinCC OA as service
Alfredo@76
ok, i found it.
Thanks a lot to everyone.
Regards.
Alfredo.
Alfredo@76
hi guys,
i think i did it well, but now i have a strange behaviour.
When i restart the server, apparently nothing happen, but when i open the Consolle, all the services are running (state 2).
But the Gedi and Vision managers doesn't work, it means that both are at state 2, but the graphic interfaces doesn't pop up.
I have to say also that i'm running a test in a virtualized server whitout WinCC OA licences.
Could the licences be a reasone of this behaviours?
Reagards.
Alfredo.
Alfredo@76
If i stop the WCCILpmon service from the Windows services, the GEDI nad Vision come back to work normal, otherwise they don't.
Following the events since i've started the vision manager.
At the end say: Waiting for user and password, but the panel put it in, never appear.
WCCILpmon (1), 2020.05.25 17:05:22.532, SYS, INFO, 24/pmon, Got START command from ::1, starting the manager WCCOAui(1) at index 24
WCCILpmon (1), 2020.05.25 17:05:22.532, SYS, INFO, 1, Manager Start, C:\Siemens\Automation\WinCC_OA\3.15\bin\WCCOAui.exe -PROJ PR -pmonIndex 24 -p vision/login.pnl
WCCOAui (0), 2020.05.25 17:05:22.670, SYS, INFO, 1, Manager Start, PROJ, PR, V 3.15 - 3.15 platform Windows AMD64 linked at May 1 2018 14:00:29 (4c82dace2be)
WCCOAui (0), 2020.05.25 17:05:22.682, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ WIN-PG51URAK37J:4897
WCCOAui (0), 2020.05.25 17:05:22.683, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ WIN-PG51URAK37J (::1)
WCCILdata (0), 2020.05.25 17:05:22.692, SYS, INFO, 4, Connected to (SYS: 2 Ui -num 1 CONN: 1) @ WIN-PG51URAK37J (::1)
WCCILdata (0), 2020.05.25 17:05:22.707, SYS, INFO, 0, , Manager (SYS: 2 Ui -num 1 CONN: 1) initialised
WCCOAui (1), 2020.05.25 17:05:22.715, SYS, INFO, 6, Initialization by Data Manager finished
WCCOAui (1), 2020.05.25 17:05:22.717, SYS, INFO, 3, Trying to connect to (SYS: 2 Event -num 0 CONN: 1) @ WIN-PG51URAK37J:4998
WCCOAui (1), 2020.05.25 17:05:22.722, SYS, INFO, 4, Connected to (SYS: 2 Event -num 0 CONN: 1) @ WIN-PG51URAK37J (::1)
WCCILevent (0), 2020.05.25 17:05:22.725, SYS, WARNING, 105, Invalid license, WIN-PG51URAK37J: No license found, Running as demo version, ui
WCCILevent (0), 2020.05.25 17:05:22.726, SYS, INFO, 4, Connected to (SYS: 2 Ui -num 1 CONN: 1) @ WIN-PG51URAK37J (::1)
WCCOAui (1), 2020.05.25 17:05:22.727, SYS, INFO, 102, Waiting for user names/passwords
WCCOAui (1), 2020.05.25 17:05:22.729, SYS, INFO, 103, User names/passwords initialized
