Tree widget: first click on checkbox fails
weirdal
Post by weirdal »
We are using the tree widget in checkbox mode (v3.15 p11).
Initial click on a checkbox does not receive data in the clicked() event; the event is triggered, but the values are empty:
clicked(string id, int column)
First click:
WCCOAui1:["Id: "]["Column: -1"]
Second and following clicks:
WCCOAui1:["Id: 1.2.1"]["Column: 0"]
Secondly, the tree widget has some issues when initialising in GEDI:
Start GEDI, open panel with tree widget on it, click on tree widget, switch to register "Extended" in Property Editor.
The first time after GEDI was started, the "clicked" event won't show the text "-script defined-" and when opened it is empty.
After closing and re-opening the panel, the script content is being displayed as expected.
Re: Tree widget: first click on checkbox fails
is the tree already completely initialized before you click?
i tried with Patch 24 and if the Tree widget is emtpy im getting "[""][-1]"
I couldn't reproduce the gedi error.
