WinCC OA 3.17 problem with "FramelessWindowHint" on Windows 10
casadofer
Post by casadofer »
hello,
we are using the 3.17 P003 version of WinCC OA in a operating system Windows 10. When we use the flag "FramelessWindowHint" in the function "windowFlags" in order to remove the frame of the window, the window/panel is closed and there is not trace about this in the Log Viewer. Other flags works properly. We have tested this in windows 7 operating system an works fine. does Somebody have the same problem or know because it happens? Thank you.
Fernando Casado - SW engineer in SICA s.a. (Spain)
rcampos
Re: WinCC OA 3.17 problem with "FramelessWindowHint" on Windows 10
Post by rcampos »
We are having the same problem using WinCC OA 3.17 P03: when we use the option FramelessWindowHint, it works properly if the SCADA runs in Linux, but when the SCADA runs in Windows 10, the panel opens but it is closed immediately.
What can we do to solve this problem?
Thanks in advance
Andorhal
Post by Andorhal »
Thanks for the info.
We will look into this.
best regards
casadofer
Post by casadofer »
Solved in WinCC OA 3.17 P005
