At "Direction" you have selected "AM_Output" which sounds like an output and not an input address.
In the simulation file you have defined times which shall be used when setting a value. Also you have used the option "-2" which defines that the values will be set in a loop. You have to take into account that new original values with a defined time can only be set if the time is equal or newer to the time which is already saved at the dp element. When trying to set a value with an older time the time will be corrected and the statusbit _stime_inv will be set.
To start the simulation you have to set the dp element _Simulator_<num>.Signal to 1. If the value is set again the simulation is stopped.
In the log file for the simulator you will find information when the simulation is stopped and started.
