I have a panel that has several instances dynamically loaded by root panel. I would like each instance of the sub-panel to be displayed at a rotation specific to that instance. Each instance is loaded using the addSymbol function, there is an angle parameter that I was hoping would do this but I have found the behaviour of this is not as I hoped, for instance a rectangle within the panel displays as a parallelogram - probably as the centre of rotation is not the corner of the rectangle?
I therefore pass the rotation angle as a dollar parameter to the sub-panel and on intialise rotate the rectangle using its .rotation method - this works as I would like. The issue I now have is that I also need to rotate labels and textfields contained in the same sub-panel but cannot find a means to rotate these type of object directly?
Thanks in advance for any help.
Rotation of panel / labels
Re: Rotation of panel / labels
Every reference has a a reference point. This one is used as center for the rotation.
When rotating objects you have to take into account that not all objects can be rotated, e.g. rotating a text field or a button is not possible.
- mikek10
So even if I rotate the panel you are saying text fields and labels won't rotate? That seems like quite a major oversight considering its a simple task in visual studio or most other high level languages for producing GUIs! Its more work than I anticipated but could a custom EWO be a solution?
Additionally - if I set a rotation value in addSymbol and the panel reference point is set the same as the first corner of the rectangle I still get some instances where the display is a parallelogram rather than the rectangle it should be! if I rotate in addSymbol with a textfield or label in the panel the rotation is not performed which is probably due to the language limitation you already mentioned?
If a reference contains an object which cannot be rotated the rotation parameter will be ignored when using addSymbol().
I made some tests with a reference containing of rotateable objects and addSymbol().
The rectangles will be a "parallelogram" if the scaling parameters do not have the same value. When the scaling parameters have the same value the rectangles are only rotated but not transformed.
