We have configured the three distributed system ; it was working when i have configured with 2 distributed system .
Afterwards always i am getting proxy time out error.
WinCC OA version which we are using is v3.15 P015.
WCCILevent (0), 2020.04.29 07:55:49.711, SYS, INFO, 1/event, Received message from MAN: (SYS: 40 Dist -num 1 CONN: 1) with and ID 38 smaller than the ID 211542 of the last received message, assuming manager has been restarted
WPMON_BCR (1), 2020.04.29 07:56:39.350, SYS, WARNING, 36/pmon, Blocking Manager WCCILdist(1) detected. No heartbeat since 30 seconds.
WPMON_BCR (1), 2020.04.29 07:56:56.871, SYS, WARNING, 39/pmon, Manager WCCILdist(1) is no longer blocking.
WPMON_BCR (1), 2020.04.29 07:57:26.896, SYS, WARNING, 36/pmon, Blocking Manager WCCILdist(1) detected. No heartbeat since 30 seconds.
WPMON_BCR (1), 2020.04.29 07:57:33.054, SYS, WARNING, 39/pmon, Manager WCCILdist(1) is no longer blocking.
WCCILproxy (1), 2020.04.29 07:57:34.757, SYS, WARNING, 5, Connection not possible, Closing connection to peer: ::ffff:10.50.110.51:60280. Reason: [proxy] acceptTimeout = 100 expired before configuration arrived.
WPMON_BCR (1), 2020.04.29 07:58:03.088, SYS, WARNING, 36/pmon, Blocking Manager WCCILdist(1) detected. No heartbeat since 30 seconds.
WPMON_BCR (1), 2020.04.29 07:58:19.578, SYS, WARNING, 39/pmon, Manager WCCILdist(1) is no longer blocking.
WPMON_BCR (1), 2020.04.29 07:58:49.658, SYS, WARNING, 36/pmon, Blocking Manager WCCILdist(1) detected. No heartbeat since 30 seconds.
WCCILdist (1), 2020.04.29 07:58:56.557, SYS, INFO, 0, , Connection from X862KS5551.SOUTHSTREAM.pccs.local expired; did not receive any init message
WPMON_BCR (1), 2020.04.29 07:58:56.651, SYS, WARNING, 39/pmon, Manager WCCILdist(1) is no longer blocking.
WPMON_BCR (1), 2020.04.29 07:59:46.268, SYS, WARNING, 36/pmon, Blocking Manager WCCILdist(1) detected. No heartbeat since 30 seconds.
WPMON_BCR (1), 2020.04.29 08:00:02.738, SYS, WARNING, 39/pmon, Manager WCCILdist(1) is no longer blocking.
WPMON_BCR (1), 2020.04.29 08:00:32.832, SYS, WARNING, 36/pmon, Blocking Manager WCCILdist(1) detected. No heartbeat since 30 seconds.
WPMON_BCR (1), 2020.04.29 08:00:40.007, SYS, WARNING, 39/pmon, Manager WCCILdist(1) is no longer blocking.
WCCILproxy (1), 2020.04.29 08:01:03.546, SYS, WARNING, 5, Connection not possible, Closing connection to peer: ::ffff:10.50.110.51:60394. Reason: [proxy] acceptTimeout = 100 expired before configuration arrived.
WPMON_BCR (1), 2020.04.29 08:01:10.046, SYS, WARNING, 36/pmon, Blocking Manager WCCILdist(1) detected. No heartbeat since 30 seconds.
thanks.
R.Paramesh
Proxy Time out error in the DIST system
Re: Proxy Time out error in the DIST system
The cause for the blocking manager is possibly related to problems with the name resolution.
Can you please check if you have defined the hostnames/IP addresses for the computers used in the distributed system in the "hosts" file of the operating system.
- paramesh1985
Hi Knipp,
Thanks its working .
There is wrong name entry in the host file ; that name is not matching with the config entry host name .
After i have fixed the host name in the config file and host file its working.
R.Paramesh
R.Paramesh
