If use addUserPVSS the account "root" is modified
- Password is changed
- group is empty
Remarques
- goup and password can Resset if gedi was open during this function or restart project with an other user with root access)
- I don't use OS-ID Kerberos authentification, the panel that performs this function is only active on the server where the project is installed and has root access
dyn_string ds_UserName;
string sNewUser;
sNewUser = "TestUser1111";
// get username
dpGet("_Users.UserName", ds_UserName);
int ret = dynContains(ds_UserName, sNewUser);
if (ret > 0)
setValue("TEXT_USERPW", "text", "User exists (maybe disabled): " + sNewUser);
else
addUserPVSS("",sNewUser,"","");
addUserToGroupPVSS(getUserId(sNewUser) , 3);
setValue("TEXT_USERPW", "text", "Add New User: " + sNewUser);
Function addUserPVSS() destroy user "root*
- marcel.gay@wimag.ch
Re: Function addUserPVSS() destroy user "root*
At the function addUserPVSS() you have to pass the OS user ID.
In your case you have defined an empty string instead of a valid OS user ID and this is possibly the cause why the "root" user was changed.
perfect, it runs
I could get the ID by
mapping m;
m = getOSUser();
and m["OSID"]
Just another question:
In the "Benutzerverwaltung" I can't delete a user, but only desavtivate or activate (possible to change by CTRL _Users.Enabled), e.g. removeUserFromGroupPVSS()
Through tests I have created some "TestUser <nnnn>" and I would like to permanently delete them from the _Users database. is this possible ?
mapping m;
m = getOSUser();
and m["OSID"]
- kilianvp
its not recommend but you can delete the entries in the arrays and and write the arrays back.
be sure the user isn't member of any groups!
In WinCC OA the user ID is saved when a value is stored in the archive or when an alert is acknowledged.
If the _Users datapoint is modified and entries are deleted the same ID is possibly used again for a different user created afterwards.
When reading historical data you will then find entries which do not belong to a specific user which might cause confusion.
In version 3.17 a user can be "deleted".
The information is then deleted from the _Users datapoint and transferred to _Deleted_Users.
This solution was implemented to prevent the duplicate usage of the same user ID.
There is a mistake in the docu and I would like to add some information
Synopsis
int addUserPVSS(string osID, string userName, langString userFullName = "", langString userComment="");
in Help:
addUserPVSS() Rückgabewert Bei Erfolg 0, bei Fehler -1.
Correct is:
Rückgabewert Bei Erfolg "UserID -> c0......", bei Fehler -1 is correct
I had the problem that with a new addUserPVSS (string not a new one but the last user overwritten again and again, activated if not active and the group was removed
The OS ID is a kind of key that is used and is assigned to each user differently
I always generated the OD from the user root and was therefore always the same as what did not work
Since I do not need the OSID but each user must have a different value (otherwise PCSS New USer does not work), I have created a unique value with the date and time. Otherwise I don't use it and this is not a problem for my application.
Finally, our in-house developed SSO is ready and functional
Synopsis
in Help:
Correct is:
