Driver setting status bits only
mhargreaves
Post by mhargreaves »
We are creating a driver manager using the C# API and are trying to set status invalid, which is working through the SetSbit on HWObject, but it seems we have to SetData also. Is there a way of setting the status bit without updating the data for the hardware object?
If we do not call SetData the value is set to 0 when we call GetSlfPtr().ToDp(). Also if we call GetData for the HWObject we get 0 regardless of the real value.
Re: Driver setting status bits only
I had a look at the source code for the S7 driver which supports the feature to set the _invalid bit when the PLC connection is lost.
The code uses "setData" and "setSbit".
It looks like it works this way and not without using "setData".
adaneau
Post by adaneau »
I think this is normal because a change of bits should also trigger dpConnect functions (e.g. in case of connection loss), thus you need to use setData (and yes unfortunately I think it also change timestamp and value).
Alex
