login panel for SSA
tmalone
login panel for SSA
Post by tmalone »
In the new 3.17 standard project, you are presented with a login panel that has text like
http://localhost:4434
(project name @ computer name)
It does not comply with the loginFramework panels and does not follow the standard from the manual:
The background image for the login panel "login_background.png" can be changed in the directory <proj_path>/pictures.
Where does this panel come from?
Todd Malone
Malone Computing Service, LLC
adaneau
Re: login panel for SSA
Post by adaneau »
Hi Todd,
If you use SSA, this is a qt generated window. You can only change picture but not customize it. It is because it runs before even UI starts, so it cannot rely on pnl/xml files.
Alex
n.kuehl
Post by n.kuehl »
I cannot change the background by putting a png file "login_background.png" at the pictures folder in my project. I also replaced it at .../3.16/pictures/... and no effect. The new png has the exact same dimensions and bit depth. No error logs.
Any ideas what I'va done wrong?
