We have a ULC UX project and we use our own developed sso handling, a customer server manages the passwords.
The customers change the passwords in their system (not in WinCC-OA)
if a customer now logs in directly via the ULC UX client and not via sso, he would like to use his password
Every authorized user is created in WinCC-OA with the same username but no longer with the same password if it was changed after a certain time
We receive the users and passwords via another interface, so we could adjust the passwords automatically
Is it possible to query and change the passwords in Wincc-OA via ctrl for every user (root is not necessary) ?
ask/change passwort from ctrl
- kilianvp
Re: ask/change passwort from ctrl
yes you can use "checkPassword()" to check the password and "crypt()" to create the new password and store it in "_Users.Password"
- adaneau
Just my few cents on this.
Transferring password in clear text via network is a big security thread. You will need a good encryption between WinCC OA and your third party system. Moreover this is also an exposure to MoM attacks. I wouldnt use such mechanism in sensible environment.
If you wanna delegate your auth to another system than WinCCOA, then you should have a look into "User-defined Authentication" feature. This is far more complex indeed but far more secure. It uses cpp code and overwrite winccoa auth with your own.
Best regards
Alexandre
Best regards
Alexandre
- marcel.gay@wimag.ch
Thanks for all the tips.
The system is running in a private network without an internet connection.
Access is only possible via VPN limited to our own machines
Just a final question
I find in para the datapoint _users with "UserId", "Fullname* and "Password" and more .....
to change password there is: _Users.Password
with checkPassword I can check if the password is changed/the same
I crypt password with: passw = crypt(s_password,3);
But how I write/change a modified password (a panel/ctrl running with authorization level "root" processes this) ?
Is there à function ?
- kilianvp
main()
dyn_string ds_UserName, ds_Password;
// get username and password
dpGet("_Users.UserName", ds_UserName,
"_Users.Password", ds_Password);
int ret = dynContains(ds_UserName, "root");
if (ret > 0)
// set password for user
ds_Password[ret] = crypt("neue Passwort",3);
// write back
dpSet("_Users.Password", ds_Password);
else
DebugTN("can't find user");
}- marcel.gay@wimag.ch
Running perfect. Thank you !
If this solution with the dpSet() works depends on the version you are using.
In WinCC OA 3.17 the _Users datapoint has an _auth config which defines which users/managers are allowed to modify the dp elements.
This also applies to other internal datapoints.
You have to take this into account when trying to set internal datapoints.
