Thanks for reply.
(viewtopic.php?f=16&t=11012)
So, I tried to communication OMRON PLC using Ethernet/IP Driver in WinCC OA.
I set up
- Common settings : ControlLogix
- IP Address : OMRON PLC's IP Address
- Slot number : OMRON PLC's Slot number
- Timeout(ms) : 50000
-Connections : 1
- Message size : 500
Sadly, There were two problems.
Firstly, I saw packet using wireshark.
and packet showed
- Originator Vendor ID : Real Time Automation(C&ID) (0x0032).
so, I receive "Connection failure : Connection Manager - Forward Open".
I set up same in Kepware to compare WinCC OA's packet
and then, I saw packet that packet showed "Originator Vendor ID : Unknow(0x051b)"
and I receive "Success: Connection Manager - Forward Open.
Connection could not be made on WinCC OA even though it was set to the same protocol.
setup information is in this link
viewtopic.php?f=15&t=11023
secondly,
Perhaps the service code Ethernet/IP Driver in WinCC OA and Omron are different.
In order to read Byte data, OMRON's Service code is 0x1C.
but perhaps WinCC OA's Service code is 0x52.
So, I want to change this.
What can I do?
How to change Service code in EIP
Re: How to change Service code in EIP
I had a short discussion with our developer and checked the documenation.
A connection to OMRON PLCs is officially not supported by the WinCC OA EIP driver.
We have not tested them and therefore we do not know if the work or not.
