I need to rotate a primitive text in a script. Using property "rotation" does not work directly. In GEDI one needs to set "transformable" first, but I cannot seem to find the correct way to set this using setValue?
Primitive text - transformable
Re: Primitive text - transformable
Why is there a need to set the "transformable" attribute via script?
If you already know that you want to the have it transformable you can set it in GEDI.
- ottemot
There is a need if you dynamically add a rectangle shape using addShape() and need to change transformable from its default TRUE.leoknipp wrote: ↑ Fri Mar 27, 2020 8:39 am Why is there a need to set the "transformable" attribute via script?
I have the same issue, is the transformable property hidden in some other attribute or under a different name?
Using 3.18.
If you want to fulfill this special requirement you can define a reference object (panel with a rectangle which has the required options set) which is then loaded via addSymbol() instead of loading a new shape.
