Vision window name without panel
hbraun
Post by hbraun »
Hello everyone,
You can set the window name of the vision module with "-m" option of the UI. E.g.
-p testPanel.xml -m vision:"myWindow"
But this way the window in windows is always the name specified at the -m parameter + ":" + the panel. E.g.
"myWindow:testPanel.xml"
Is there any way to get a window without the ":" + panel?
Thanks and kind regards,
HBraun
adaneau
Re: Vision window name without panel
Post by adaneau »
Cant you use the function setWindowTitle() to put title of your choice at initialization?
Otherwise I have no idea using -m option of UI manager...
Alex
If you start the UI only with the option "-p <panel file>" a Vision modul is opened with the specified panel.
There is no need to add also the -m vision option.
hbraun
Post by hbraun »
Thanks a lot, setWindowTitle() works perfectly. I can omit the -m paramter now.
