before updating our datapoints, we would like to "reset" the alias from every DPE to avoid conflicts with the new update.
The way building a loop doing a "dpSetAlias(dpe, "") " to all of the available DPEs seems to be not much performant as it is doing individual dpSets many times.
for (j = 2; j <= dynlen(queryResult); j++)
sDPEname=queryResult[j][1];
dpSetAlias(sDPEname,"");
Is there any way to provide a dyn_string to do that with only a call (like dpSetAlias(dyn_string, dyn_string)
dpSetAlias for multiple DPE
Re: dpSetAlias for multiple DPE
The documentation gives the information that using dyn arrays is not possible for dpSetAlias().
If you want to check if an alias is already defined you can call dpGetAllAliases() with a search pattern for the alias.
Based on the result of the function you can check if there is a need to delete an alias at a specific element.
