Hi, I'm trying to implement the SampleUtilTab example as API Control Extension in Alarm List, using WCCOA 3.17, P002. It is compiled fine in VS2017, but once declared in AES Configuration, as detailed in the Help files, the following error is reported in the Log Viewer:
WCCOAui (1), 2020.02.24 10:31:27.199, CTRL, WARNING, 54, Unexpected state, SharedLib, userDefFunc, Error when calling tabUtilTranslateDirection in : The parameter is incorrect.
WCCOAui (1), 2020.02.24 10:31:27.207, CTRL, WARNING, 77, Expression is not an array,
Module: WinCC_OA-AES
Panel: C:\Workspaces\RailComCore\Projects\Scada\RailComCore\panels\vision\aes\AEScreen.pnl [AEScreen]
Object: 1 named: "table_top" of type: TABLE
Script: Initialize
Library: C:\Siemens\Automation\WinCC_OA\3.17\scripts\libs\aes.ctl
Line: 19109, dynlen
WCCOAui (1), 2020.02.24 10:31:27.213, CTRL, SEVERE, 176, Uncaught exception in thread started at aes_workCB:
WCCOAui (1), 2020.02.24 10:31:27.207, CTRL, SEVERE, 79, Index out of range,
Script: Initialize
Line: 19109, xtab, 2
Stacktrace:
1: aes_formatPriorityToInt(dyn_dyn_anytype & xtab = ({ 0 items })) at aes.ctl:19109
2: aes_workCB(string ident = "1_0_1_0_FA ...", dyn_dyn_anytype tab = ({ 1 items }), bool fromDpQuery = FALSE) at aes.ctl:3793
I've tried the default generated one ("add") too. As soon as I declared it in AES Configuration, in order to add, for example, _ack_state +_ack_state, the same error as above is reported.
Can I ask for your advice, please?
Thank you.
API CtrlExt Error
- tobias_raab
Re: API CtrlExt Error
Hey Arthur,
did you find the cause of your issue? I'm getting the same error at the moment.
Tobias
Tobias
The problem is possibly related to the function aes_formatPriorityToInt().
We have fixed a problem with this function in WinCC OA 3.17 P007.
Please install the newest patch for WinCC OA 3.17 and check afterwards if it works.
