we need to know if is possible to identify the alert duration of an alert by adding column in History aes screen; about time we find only:
_ack_time
_came_time
_gone_time
_del_date
_partner
_system_time
It's possible to retrieve this information in a simple manner?
Thanks in advance.
Regards.
Alert duration
- kilianvp
Re: Alert duration
I don't understand what you want to do.
There is no possibility to display the duration in real time.
Basically, the duration can only be calculated between two states.
- orla090978
Re: Alert duration
OK thanks for the reply.
Regards.
Regards.
Re: Alert duration
As already written the duration you have to calculate on your own.
The attribute _partner_time is only set if there is already a gone alert exisiting for a came alert.
