How can I create a link for the web page. For instance, I want to open web page(www.etm.at) when pressed the buttton.which function can be called in button click event.?
Thank you
Web Page Link
- vogler
Re: Web Page Link
you can do it with a system command:
system("\\"C:\\Programme\\Internet Explorer\\iexplore.exe\\" \\"www.etm.at\\"");
or you can also integrate a browser in your application (evo or active-x).
brgds.
Andy
brgds.
Andy
- hakan
Re: Web Page Link
It is working on local system. But It is not working on web client(on applet). When I try the on web client appear message on log viewer. Message is below
"system, "C:\\Program Files\\Internet Explorer\\iexplore.exe" www.etm.at not in whitelist, ignored"
Best Regards,
hakan
Best Regards,
hakan
Re: Web Page Link
You could use the default webbrowser with the command:
You should also be able to use the command:
system("start http://www.etm.at");Code: Select all
std_help("http://www.etm.at");- hakan
Re: Web Page Link
std_help("http://www.etm.at") function is not working
system("start http://www.etm.at"); function is working on local system. But It is not on webclient. Web Client message is below
"system, start http://www.etm.at not in whitelist, ignored"
I need to work on web client
bstrg
Hakana
bstrg
Hakana
Re: Web Page Link
You will need to include the part, otherwise the std_help function will not work.
http://- Gertjan van Schijndel
Re: Web Page Link
Perhaps the older version of 'std_help' also checks if the url ends with '.htm' or '.html'.
In that case this should work:
You could also look in the 'std_help' function to see why it does not work.
std_help("http://www.etm.at/index.htm");- frankySie
Re: Web Page Link
here's a solution which I use. But it is unknow if this will work for web client:
a panel was defined with an activeX control , type microsoft-web-browser.
a initialize method was implemented for the activeX control:
main()
this.Navigate("http://that-is-the-link");
main()
Re: Web Page Link
I think theTS is using the javaUI, because he talks about a (java) applet. So he cannot use an activex or ewo.
But since he did not provide much information regarding his configuration, we cannot be sure. Although the error message comes mostlikely from a system-call thru the xmlrpc interface.
