Can you, please, advice how to use ulc ux in the projects where some multimonitor clients are also required? Thinking about that I have some questions.
[*] Can one user be logged to multiple ulc instances at the same time?
[*] Is it possible to open user defined panels specified by URL without being prompt again for login/password if user already logged in to other window/tab? I know it is possible to open any panel if allowPanelParam=1, but should not be allowed if user did not log in before.
[*] Can other parameters be passed to the application/panel by URL?
[*] Can another UI instance (window/tab) be opened from current instance?
Kind regards,
Oto Kuzma
ULC UX capabilities
Re: ULC UX capabilities
Here is some information your questions:
1) A user can connect to different WinCC OA systems using different tabs in the browser.
2) I do think that this is possible as every tab is a new connection to the ULC UX server and therefore a new UI is started at the server.
3) What parameters are you talking about?
4) As far is I know this is not possible.
