I am following the WCCOA C# API guide in the help documents and believe I have followed all the steps correctly. However when I step through the C# code the project crashes on the following line:
myManager.Init(ManagerSettings.DefaultApiSettings, args);
with the error: The program '[10548] WCCOACSAPITest.vshost.exe' has exited with code 1 (0x1).
Should I be able to step through the code in debug mode or will only the compiled exe in the project\bin path work?
WCCOA C# API in debug mode?
Re: WCCOA C# API in debug mode?
If you want to debug a WinCC OA process you can
-- Start the process
-- Attach with the debugger to the process
-- Start debugging
-- Start debugging
