How to use OS Auth and guest user
amichon
Post by amichon »
I'm looking for a solution to use the Auth OS. and log in with a default user on the WinCC OA application.
This default user could might be typically a guest user having only visualization permissions.
It's not possible to use in same time Auth OS. mode and local users but maybe there's another way to do that without adding the guest user in the Active Directory users list.
Re: How to use OS Auth and guest user
When switching to OS authentication all standard WinCC OA users are deleted.
There is no possibility to use a non OS user for the login in WinCC OA.
You can possibly try to start the UI without login panel and without a defined user.
Then WinCC OA will run as default user.
amichon
Post by amichon »
Thanks, i will try this way.
