How to address a variable name by combining strings
Kirvesmies
Post by Kirvesmies »
This is just a stupid example, but how can I get the code to understand I want to set fValue1 value to 123.4?
float fValue1;
int i=1;
("fValue"+i) = 123.4;  //One cannot point to a variable by combining texts it seems
EER
Re: How to address a variable name by combining strings
Post by EER »
I think its not possible.
Something that looks like your example:
  dyn_float dfValues;
  int i =1;
  dfValues[i] = 123.4;
But this does not compose a variable name using strings. In most cases you don't need to do this anyway.
I don't know what problem you try to solve but try to use lists or maps to structure the data.
Avoid defining variable references during runtime. In general this will make the code hard to read and predict.
dvribeira
Post by dvribeira »
I will not get to rewriting what you want, but to give you a hint, you can generate a script, i.e. write it to a string, and then execute it with evalScript() or execScript().
The example given by "EER" is to read an entry in a dyn_array. It does not compose a variable name.
With the function setVariable()/getVariable() you can probably do what you want.
But as mentioned using dynamic variable names must not be used.
Kirvesmies
Thanks guys. Problem solved. I did not know you can use dyn_variables in the callback function parameters so here is the old and new dpConnect:
OLD:
dpConnect("WS_CB", TRUE,  $dpe+".fValue1:_online.._value",
	$dpe+".fValue2:_online.._value",
	$dpe+".fValue3:_online.._value"....");
WS_CB(string dpe1, float fValue1,
	string dpe2, float fValue2,
	string dpe3, float fValue3...,)
dyn_float fValue;
 for(int i=1; i<10; i++)
 	fValue[i] = ("fValue"+i); //No good
NEW:
WS_CB(dyn_string dpe, dyn_float fValue)  //Good
If you are defining the dp elements for the dpConnect() element by element do not pass a dyn_string to the dpConnect() it is possible better and easier to read when you do not use dyn_arrays in the work function.
In the work function you see then directly which dp elements and which value belongs to which dp elements in the dpConnect() call.
