Curious if it's possible to set windowFlags from outside the actual panel which is being affect, say from a button which sits on that particular panel?
I've got around 50 panels which need to have the parameter "WindowStaysOnTopHint" set using:
setValue("","windowFlags","WindowStaysOnTopHint");
but I'm not so keen on modifying every single one, so thought I could use an already existing object_ref which sits on all of those panels and set the parameter from the initialise script on this obj_ref. Unfortunately this doesn't seem to want to work, I've been trying passing the name of the panel as the first parameter like this:
setValue(myPanelName(),"windowFlags","WindowStaysOnTopHint");
which returns an error saying object "###panel name###.pnl" doesn't exist. Also tried the following which also errors:
setValue(myModuleName() + "." + myPanelName(),"windowFlags","WindowStaysOnTopHint");
[Tried cutting out the ".pnl" at the end of the panel name - same thing, also an error.]
So my question is: can "windowFlags" for a particular panel be modified outside panel scripts, on panel shapes / object refs?
setting windowFlags from outside panel scripts
- tpjctrl
Re: setting windowFlags from outside panel scripts
If you want a module to be on top you can use the function stayOnTop() where you can define the module name.
Then you do not have to do it for every panel.
- gschijndel
Try it with the following shape name:
setValue(myModuleName() + "." + myPanelName() + ":", "windowFlags", "WindowStaysOnTopHint");- tpjctrl
Thanks for the hint gschijndel, it's the ":" which was missing and causing errors.
