control script for removing periphery address
- mcmullan
How do you delete an address config via scripting without deleting the actual dp?
Re: control script for removing periphery address
If you want to delete a config simply do a dpSet() for the _type attribute with value "0" (null).
- gschijndel
I would advise to use the constant 'DPCONFIG_NONE' instead of the value zero for readability.
- mcmullan
dpSet("System1:global_vars.NameDemo:_address.._type", DPCONFIG_NONE);
Seems to do the trick.
Thanks!!
Thanks!!
