I have two project configured as service on the same client. I am trying to connect to the two project through desktop UI, I configured different httpsport for each however; it seems it only connects to the service which starts first and does not connect to the other. Is it possbile to connect two the project through desktop UI? See attached for current configs
Thanks.
Desktop UI connection to 2 projects
Re: Desktop UI connection to 2 projects
Please take into account that running 2 server projects on the same machine is prohibited.
Are you running complete server projects on the same machine or only the webclient_http.ctl scripts which connect to other server projects?
Please check the PVSS_II.log file for both projects, maybe you get an error when starting the webclient_http.ctl script that the httpPort cannot be opened as both projects are using the standard port 80.
