we are in the process of creating a WinCC OA project with Active Directory authentication.
On our development machines, we can switch to AD authentication ('OS Auth.') and use our corporate AD.
Now we want to create a test machine in the customer environment to start testing in their environment and their AD.
However, the option 'OS Auth.' is not in the list under user administration, only the empty field and 'Standard'.
In both cases, the user is a normal domain user.
What is the trigger used by WinCC OA that makes the option 'OS Auth.' available?
Is there a way I can test this requirement on the command line?
WinCC OA: 3.16 P012
Windows 10
Best regards
Frank
Requirements for OS Authentication
Re: Requirements for OS Authentication
If you want to switch the authentication type you must be root user.
Please check if the panel works when running as root user.
- gschijndel
A windows machine must be part of a domain.
- fleitner
Thank you for the answers. It turns out there was an issue with domain connectivity on the customer network, which likely caused this issue.
