Bar Trend Error
jjang@gtd.eu
Bar Trend Error
Post by jjang@gtd.eu »
I'm trying to use a Bar Trend. So I create a dyn_float DP in PARA and I wrote the following command (easy and simple command):
---------------------------------SCRIPT-------------------------------
─// [balken] [1] - [RotateAngle]
main()
dpConnect( "work", "ExampleDP_bt.bt1:_original.._value" );
work( string dp, dyn_float y )
setValue( "balken", "data", y );
setValue( "balken", "flush" );
DebugTN("Ha entrado aqui");
─// [NEWDATA] [2] - [Clicked] <-- It is a PUSHBUTTON
main(mapping event)
dyn_float random_value;
for(int i=1;i<=24;i++)
float random_aux;
random_aux=(rand()/16000)-0.5;
random_value=random_aux;
dpSet("ExampleDP_bt.bt1:_original.._value",random_value );
But I does not work and in Log Viewer says that Object "balken" of type "BAR_TREND" does not know the attribute "data" for "setValue()".
I don't understand why it does not work because the example panel of WinCC OA uses the same function and it works.
Re: Bar Trend Error
Depending on the type of bar trend you are using the attribute "data" requries 1 or several variables.
Did you check that you are using the bar trend type which fits "data" with only 1 variable?
Please take into account that the bar trend has some limitations, e.g it cannot be used in panels using the xml format.
jjang@gtd.eu
Re: Bar Trend Error
Oh.. I'm using XML format of panels... so it must be the problem...
Is there any way to make this problem available?
Thank you so much...
Re: Bar Trend Error
There are no plans to support the bar trend in xml panels.
If you want to use the bar trend you have to save the panels in pnl format.
