WinCC OA 3.16 on Redhat 7.5 x64, Unable to Open UI.
bennettan
Post by bennettan »
Hi, I tried to install WinCC OA 3.16 on Redhat 7.5x64.
When I click on the Project Administrator or Console, not thing popup on the screen.
By using the command, it returns the project administrator or console is started.
Anyone know what is the issue or what do I missed?
adaneau
Re: WinCC OA 3.16 on Redhat 7.5 x64, Unable to Open UI.
Post by adaneau »
Did you try as su? Maybe some permissions are not set for your current user.
Alexandre
bennettan
Post by bennettan »
I tried the su, still the same. nothing happens.
I run from the command startPA and startConsole, it show is running but nothing show on the GUI.
gschijndel
Post by gschijndel »
Check if the DISPLAY environment variable has been set. And try the command with additionally '-display :0' (might need to replace ':0' with the right display value).
