Query Error "Too Many Values"
shokkul
Post by shokkul »
config values related to query
[valarch]
queryMaxValues = 0
[event]
maxDpNamesCount = 0
[data]
maxLinesInQuery  = 0
maxValueRequestCount  = 0
Error in the Logfile
WCCOAui      (1), 2019.12.10 14:58:11.912, PARAM,SEVERE,    143, Query aborted with the following error: HistQuery, constructAnswerMsg, archive request returns an error - too many values!
Hello All,
I am using query for historical data and I get "too many values" error. I already set config files for removing limitations for query but I am still experiencing query error. What can I do to get rid of this error?
Re: Query Error "Too Many Values"
If you search the Knowledge Base --> Log-Messages for this error you will find an entry for it:
https://www.winccoa.com/knowledge-base/ ... df0a7b602f
shokkul
Post by shokkul »
Hello Leoknipp, thanks for your reply,
Yes I found this entry and according to that entry I set maxLinesInQuery and maxValueRequestCount option to zero but I am still getting too many values error. Is there any other reason that I encounter this problem?
Which type of archiving are you using?
If HDB archiving is used you possibly have to modify the limits for the HDB managers too.
Please have a look at the PVSS_II.log file to see if you get log message from other managers when trying to read data.
shokkul
Post by shokkul »
I fixed the issue with set maxLinesInQuery and maxValueRequestCount option to very high value (10.000.000) so it means setting these values to 0 doesn't remove the limiters. I think it's a bug
We have not seen problems when deactivating the limits for the queries.
Please take into account that you must use useful limits. Huge queries will take a lot of time and also processing the result will take time and will possibly cause a high memory usage.
Have you been using the value 0 for both entries and it did not work?
Have you restarted the system after modifiying the config files?
How many results/values do you read from the database and what is done with the data?
