Can I use AEScreen and AESRow together?
jjang@gtd.eu
Post by jjang@gtd.eu »
Hello guys,
I made some buttons to filter the alarms and it works for AEScreen and AESRow.
Also I configure for each table the visible columns modifying the internal dp (_AESConfig for AEScreen and _AESConfigRow for AESRow).
This works when I simulate individually but when I punt both alert table together, it only picks 1 configuration for both....
I don't understand why it doesn't work :( .
Can someone help me?
Re: Can I use AEScreen and AESRow together?
If you want to use more than 1 AESrow/AEScreen in the same UI you have to ensure that every instance of the AESRow/AEScreen is running in an own module, it can also be an embedded module.
jjang@gtd.eu
As you can see in the picture attached, the first table (1) is an AEScreen and the second table (2) is an AESRow.
I see that the filters I have created only modifiy the second table that is what I wanted.
So what do you mean with "ensure that every instance of the AESRow/AEScreen is running in an own module"? How can I configure it?
I need to visualize different columns for each table, so I made this for AESRow copy panel:
TRESROW = makeDynBool(true,true,true,true,true,false,false,true,true,false,false,false,true,true,true,false,true,false,false,false,false,false,false,true,true,true,true);
dpSetCache("AGC:_AESConfigRow.tables.alertTable.columns.visible:_original.._value",TRESROW);
And I made this for AEScreen copy panel:
TODO = makeDynBool(true,true,true,true,true,false,false,true,true,false,true,false,true,true,true,true,true,true,true,false,false,false,false,true,true,true,true);
dpSetCache("AGC:_AESConfig.tables.alertTable.columns.visible:_original.._value",TODO);
The dp elements you have modified are the datapoints for the global AES configuration and do not affect the configuration for already opened AESRows and AEScreens.
If you want to use specifiic settings for a the AESRow / AEScreen you can possibly use the following approach. The AESRow /AEScreen has a $-parameter where you can defined which filter settings shall be used:
-- Define global AESRow / AEScreen filter settings in System Managment --> Settings --> A&E - Row/Screen
-- Define the configuration name as value for $-parameter for the AESRow / AEScreen
