I get the following error in a dpTypeCreate() call.
Function itself is returning 0 (indicating success), but I get the following error during such an operation. Also, the DP type does not get created.
Did anyone have a similar issue before and have an idea about the possible reason?
WCCILdata (0), 2019.12.04 12:06:06.771, PARAM,SEVERE, 36, DM: Incorrect name syntax, PersDpIdentification, handleManipTypeMsg, Typ- or Elementname wrong
dpTypeCreate() error
Re: dpTypeCreate() error
It looks like the names for the elements are wrong.
Have you tried to create a similar dp type using the PARA module?
You can create the type in the PARA module and read then the information with the function dpTypeGet().
Then you can see how the information must be defined if a new type shall be created.
