SUM_Alert - _act_state and _act_state_prior attributes
AMRPatricio
Post by AMRPatricio »
Hi all,
Do the _act_state and _act_state_prior work in similar manner when used in a dpConnect?
1. I do have a Sum_Alert with a DP list of 100 DPs.
2. One dpConnect to the _act_state of the SUM_Alert :
(dpConnect("check", "W.:_alert_hdl.._act_state");
3. One dpConnect to the _act_state_prior of the SUM_Alert:
(dpConnect("check2", "W.:_alert_hdl.._act_state_prior")
“Check” function is executed each time the sum_alert state it changes (as I do expect). However “Check2” function is executed each time one of the 100 DPs is executed.
In other words, if I do change the 100DPs at same time, Check function is executed one time, check Check2 is executed 100times.
Is it normal?
As I am connected to a sum_alert, I do not understand the behavior of the Check2 function.
Antonio Patricio
Re: SUM_Alert - _act_state and _act_state_prior attributes
Maybe the following explanation helps to understand the behvaiour,
A summary alert can have several states, similar to a single alert: no alert, came unacknowledged, came acknowledged, ....
If the state changes the work function for _act_state is called.
The priority of the summary alert is defined by the alerts which are referenced by the summary alert.
Even if the state of the summary alert does not change possibly the priority may change. Therefore you get an update for _act_state_prior every time.
Here is an example:
-- The summary alert is raised by a referenced single alarm with priority 40
The state is "came unacknowledged" with priority 40.
-- A single alert is set with a priority 60
The state is still "came unacknowledged" but now with priority 60.
AMRPatricio
Hi Leopold,
I understood what you said., and that it was my conclusion. I decided then to create a sum alert for each priority. However the behavior it is the same. Is it normal?
Antonio Patricio
Even if you define a summary alert filtered exactly for one priority you will have the same behavior for the a dpConnect to _act_state_prior.
