dpQueryConnectAll() breaks when deleting a datapoint
siemens_dva
Post by siemens_dva »
I'm trying to show the user a dynamic list that automatically updates based on changes made to any datapoints of a specific type.
To do that I use dpQueryConnectAll() with the following query:
 "workFunc", true, "", "SELECT '_original.._value' FROM '*' WHERE _DPT = \"_MyDatapointType\""
This works dandy for creating and updating datapoints. But when I delete a DP the query breaks with the following error message:
Automatic disconnect of attributes due to config type change, DP: System1:MyDatapoint1.Element1, MAN: (SYS: 1 Event -num 0 CONN: 1)
I guess this is caused because the connected attributes are removed.
How else can I listen to a list of datapoints and react to the deletion of an object?
Re: dpQueryConnectAll() breaks when deleting a datapoint
I have tested it but I cannot reproduce it.
The test was done as follows:
-- Created a dp type
-- Created a datapoint
-- Started the dpQueryConnectAll
The work function was called.
-- Deleted the datapoint
The work function was called again.
If you want to get the information if a datapoint is deleted you can use the sysConnect() function.
