Modify XML panels with CONTROL
buec
Post by buec »
I have to modify XML panels with CONTROL. When I save the panels with fputs, the line endings are changed from LF to CR/LF. When I use xmlDocumentToFile, the line endings are preserved as LF but empty XML elements are shortened.
Variant 1:
fileToString( sPath, sFileData );
// replace icon path in sFileDate
file f = fopen( sPath, "w+" );
fputs( sFileData, f );
fclose( f );
Line endings are changed from LF to CR/LF
Variant 2:
int iDocId = xmlDocumentFromString( sFileData, errMsg, errLine, errColumn );
xmlDocumentToFile( iDocId, sPath );
Empty XML elements are shortened. Example:
Gedi: <prop name="Value"></prop>
CTRL: <prop name="Value"/>
Any idea how I can save XML panels in the same formatting as the Gedi does?
WinCC OA 3.16 P015 Windows
Best regards
Christoph
Re: Modify XML panels with CONTROL
In the past I have modified XML panels using CTRL scripts using fileToString() to read the file and fputs() to save the file.
The panels were working afterwards and I did not see a problem when editing/opening them again in WinCC OA.
