Is there a way to find the Panel in which a Datapoint is used?
like:
string sPanelFile = findDpInPanels("myDatapoint", "<wincc_oa_path>/panels/*");
BR Daniel
Find a Datapoint in Panel files
Re: Find a Datapoint in Panel files
There is no function findDpInPanels() available in WinCC OA.
In the PARA module you can rename a datapoint and it is possible to find occurrences of this datapoint in panel files.
The panel used for renaming a dp are panels/para/dpRename.pnl and dpRename_Xref.pnl.
You can have a look at the code in the panels to see how the dp names is found.
- killer007
This is exactly what i am searching for
BR Daniel
BR Daniel
