How to make WinCC OA to connect to PLCSIM 15.1
7 posts • Page 1 of 1
kairat_abilev
Post by kairat_abilev »
Hello!
I cannot make WinCC OA to connect to TIA Portal 15.1 PLCSIM using S7Plus driver. It simply does not connect - always in Connecting state. I am using PLCsim type of PLC in configuration screen for S7+ connection, but it does not connect.
Thank you in advance!
Best regards
Re: How to make WinCC OA to connect to PLCSIM 15.1
In the WinCC OA Documentation it is described what you need to take into account when using PLCSIM.
Did you have a look at the documentation?
kairat_abilev
Hello!
Yes, I have read documentation and many forums but still cannot connect to S7-1200 PLSIM 15.1 Simulation from WinCC OA 3.16 P15. Is it possible or not?
Vladislav
kairat_abilev
Hello!
Still cannot make WinCC OA to connect to different versions of PLCSIM. I have tried PLCSIM 13, 13.1, 14, 15, 15.1. No luck. Please help!
Vladislav
Kirvesmies
Post by Kirvesmies »
Use plcsim advanced 2.0 or PLCSim+NetToPLCSim
kairat_abilev
Thank you very much for your reply!
Is there a version of NetToPLCSim that works with PLCSIM 15.1? Where can I download it?
Vladislav
osy_samara
Post by osy_samara »
The PLCSIM Adv v2.0SP1 + WinCC OA v3.17 work correctly. If you use S7-driver, you need enable GET/PUT communication in PLC-project. And PLC-project must be compiled for PLCSIM. If you use driver S7+, you need make export PLC.
Br,
Ilya
