Hello!
How to change background color for Cascade Button in Windows 10? In windows 7 for this feature to work I need to disable "Use visual styles on windows and buttons" setting in System performance settings. But in Windows 10 there is no such setting, so I cannot make this button dark color with white text. Our customer wants dark color screens for video wall.
Please help me.
Thank you in advance!
Best regards.
- kairat_abilev
Re: How to change background color for Cascade Button in Windows 10
Maybe the problem is related to the Windows Theme you are using.
In the WinCC OA Documentation you can find the following information:
Windows Theme Influence on Buttons
Due to the influence of the Windows style settings for current Windows themes the background color of buttons is not displayed correctly as it is overwritten by Windows. To prevent this issue either a different UI style can be selected by using the -style parameter or the background color can be set using Style Sheets.
- kairat_abilev
Dear Leopold,
Can you please explain how to make the changes to buttons colors in WinCC OA in Windows 10? May be you can drop me a css line and kindly explain where to save that css.
Best regards
Best regards
- kairat_abilev
Thank you, I managed to make the color change for Cascade button using style sheet and the name of the button.
Content of config/stylesheet.css
#CASCADE_BUTTON1 { background-color: red }
Then the changes to the background color in cascade button settings changes the color of the button!
Thank you very much!
